JD 530 PS turns slow question
1936
10-19-2007 05:24:40
I am just the messanger for this question. The IT shop manual stated to turn the adjustment setting. This was done and no change. Full of fluid. Setting still the PS will not turn. Moving it turns slow both ways. Had been a loader tractor.
Mike M
10-21-2007 04:41:04
 Re: JD 530 PS turns slow question in reply to 1936, 10-19-2007 05:24:40
A very good chance the cylinder vane packings are worn and so could the pump. The first place to start is to obtain a copy of the JD factory service manual on this unit.Read it through and decide if this is something you want to tackle yourself ? or whoever is going to be working on it ? many experienced mechanics have met their match on these units.
johns48jdb
10-20-2007 04:02:10
could be a resriction in a line. they can come a part on the inside. mt first thought was a filter, but i don't know if they had filters on them or not. can you lossen a fitting to see if its even working at all or not. the pump may need replacing.
msb
10-19-2007 18:49:14
Might be the system needs flushed and filled with new oil.That particular design is known to build up sludge in the reservoir.Have had to dismantle some in the past to clean them up.
