JD 4350 MFWD information - made in Germany...
Steven f/AZ
10-19-2007 18:08:47
Dad is looking at purchasing a newer tractor for use with a loader in his cattle operation. He has found a JD 4350 and the only information I can find on it is that it was made in Germany. The local JD dealer is unable to find any specs as to what loader may fit or what parts are available.
Anyone have any more info for me? Any help is greatly appreciated!
Steven f/AZ
10-20-2007 14:39:01
 Re: JD 4350 MFWD information - made in Germany... in reply to Steven f/AZ, 10-19-2007 18:08:47
Thanks for the info... parts and loader availability were the primary concerns.
MSM
10-20-2007 06:22:29
That tractor will accept a 260-265-or 280 loader.I would lean more toward the 280,alot heavier built,more reach,and more lift capacity.Just get the correct frame mounts for the 4350. Same mounts as a 4440,4250,4450 etc.
As for the tractor,it should have a 466 engine,same trans options as the US versions.They usually have a few more idiot lites,a hand parking brake,it may have an air compressor and gladhands for trailer hookup in the rear.It also may have yokes on the end of the 3pt arms instead of balls,but could have been changed over.
A decent parts man should be able to locate anything you need for it.There are alot of them around the Pa/NY area, a local dealer used to import them from Europe.
