square wide front spindle
yello fello
10-20-2007 20:32:09
i have a broken spindle on a j.d. square wide front, what shaft from what tractor works best to make a replacement spindle?? no longer available from j.d. or aftermarket... thanks!!third party image
DJD-Man
10-21-2007 18:50:23
 Re: square wide front spindle in reply to yello fello, 10-20-2007 20:32:09
What is the part number of the spindle? You must have a parts book, right? As far as splindles go, believe they are still available unless you have something unique or secret. You need to supply more information. Is it a high crop?
yello fello
10-22-2007 18:50:47
 Re: square wide front spindle in reply to DJD-Man, 10-21-2007 18:50:23
AA5789R
DJD-Man
10-23-2007 08:49:46
 Re: square wide front spindle in reply to yello fello, 10-22-2007 18:50:47
AA5789R is available threw your dealer. AI. 23lbs to ship, cost of splindle is 175-85. Can also get the thrust washer, bushing, and the wheel bearing kit also. This is the 14.375 height if not mistaken. Call your Deere dealer. Good luck.
