Serial Number Help Please
regularguy
11-01-2007 06:55:04
If the serial number plate is rivited to the side of the engine block and reads SNM51TL031256T is this a 2010 model tractor? This is the only plate that I can find on the tractor.
Thanks
buickanddeere
11-01-2007 16:42:19
 Re: Serial Number Help Please in reply to regularguy, 11-01-2007 06:55:04
Where is the gear shift(s)? Doesn't the T on some engine serial numbers indicate "Turbo" ?
regularguy
11-01-2007 17:28:38
 Re: Serial Number Help Please in reply to buickanddeere, 11-01-2007 16:42:19
Thanks everyone for your help. I have found the tractors serial number plate but unfortunately it is really hard to read, the numbers look like 8N1LIC92509T I am really at a loss as that does not appear to be the serial number for this type of tractor.
4020LP
11-02-2007 08:14:44
 Re: Serial Number Help Please in reply to regularguy, 11-01-2007 17:28:38
It might help if you provided some photos or a complete description of the tractor.
4020LP
11-01-2007 09:10:47
It's not a 2010, for certain. Appears to be a 2020 or JD400 engine.
Bob
11-01-2007 08:39:46
A 2010 WOULD have the tractor serial # riveted to the RH side of the engine block, but that isn't a 2010 tag #.
It looks to me like the EGNINE # from a newer tractor.
Can you post a photo?
regularguy
11-01-2007 09:09:19
 Re: Serial Number Help Please in reply to Bob, 11-01-2007 08:39:46
Bob said: (quoted from post at 08:39:46 11/01/07) A 2010 WOULD have the tractor serial # riveted to the RH side of the engine block, but that isn't a 2010 tag #.
Dubuque numbering system
Okay, could that then be a engine tag from a 2020 tractor and the tractor serial number is missing? I'm not sure where to look for the tractor serial number and obviously I don't know too much about these things..
Thanks for your help
Ten-Twenty
11-01-2007 09:38:42
 Re: Serial Number Help Please in reply to regularguy, 11-01-2007 09:09:19
A 2020 would have the tractor serial number plate mounted on the right side of the transmission case (below the seat and above the foot rest).
