Difference between a John Deere M and MT
John Clark
01-29-2000 19:34:36
Whats the differnce between a JD M and MT and can a Standard M be converted to a MT.Any information would be greatly appricated.
Theman
01-31-2000 08:40:44
 Re: Difference between a John Deere M and MT in reply to John Clark, 01-29-2000 19:34:36
The T stands for "Two-row". It was built with adjustable rear tread on a straight axle. They were available with tricycle and wide front ends that I know of, the wide front being adjustable. The serial number plate should have the MT designation. I don't believe any were built before 1949. Yes, you could physically bolt on enough parts but then you'd have MT parts on an M. You couldn't correctly call it an MT because the nameplate would say it was an M. It would not be identified as an M with that MT rear end. (Is the purist in me showing yet?) The only truthful thing about it would be that "It's a Deere."
RonMC
01-29-2000 20:12:19
Hi - The tractors are almost identical, with mechanical differences mainly in the final drives and brakes. The basic configuration of the MT - the T stood for tricycle - was of course in its single and double trike front end.The MT also had dual touch-o-matic in its tricycle form. It was also made with adjustable front axle. The M was available with standard fixed and adjustable fronts. It would be pretty much a bolt-on to convert an M, might have to do a little hunting to find parts and such. If you pick up an I&T, it will give you the basics, but it would probably be simpler to buy an MT, then you'd have 2 stock tractors with proper numbers, and 2 John Deeres is always better. RonMC
David*
01-30-2000 12:05:32
 Re: Re: Difference between a John Deere M and MT in reply to RonMC, 01-29-2000 20:12:19
Unless you fing a MT(W) MT with wide front axle, I had one until some one else liked it better than me. David
lc
01-30-2000 05:19:17
I would think that most people today would prefer the M to the Mt. It seems tricycle fronts are out of favor now. Since most don't do row crow applications.
