2010 industrial forklift transmission woes
Joe Stewart
11-20-2007 17:18:15
Hello friends, I tried to use my early "60s 2010 gas forklift to pull a 3000lb steel tank across dry ground using a chain. I was pulling in the forward direction (which is actually reverse, since the mast is on the rear end of the tractor). When I got some tension on the chain, I let out the clutch and heard a sickening grinding sound from the tranny - immediately pushed in clutch. We disconnected the chain and abandoned the pull. Now, the tractor will still move in that direction under power, but it feels like something is dragging big time - does not make any unusual noises while moving. Moving in the opposite direction did not appear to be affected by this damage since it works fine in that direction, without dragging. I"m dreading looking inside that tranny! Does anyone have the transmission manual for this machine? Any ideas on what to look for once I get the lid off the transmission?
Thanks. Joe Stewart
