2440 with a new engine?
jody
11-28-2007 06:28:28
i'm looking at a 1979 2440 that has a new engine about 4 years ago from john deere, does anybody know about this? did they reuse the old fuel inj. pump, starter, water pump, etc.? she also has a swept back front axle, can i put a loader on her? thanks
Mike M
11-30-2007 09:42:33
 Re: 2440 with a new engine? in reply to jody, 11-28-2007 06:28:28
I GOT TO THINKING ABOUT THIS ?
If someone needed a new engine allready in that tractor was it due to improper maintenance ? And if so the rest of the tractor may be bad from lack of attention too.
jody
11-28-2007 12:57:28
the new engine ser. # t04039d573496,any ideas?
LarrySTN
11-29-2007 17:52:40
 Re: 2440 with a new engine? in reply to jody, 11-28-2007 12:57:28
the 4039 is the metric 239 cid engine. They started production mid to late 80's. They are a decent engine. They were the engine used in the 2555.
LarrySTN
11-28-2007 08:02:44
Check the numbers on the engine block. The model number will give some idea to what engine was installed and an aproximate age of the engine.
MSM
11-28-2007 07:32:42
It could have had a complete reman engine installed which would have new/rebuilt inj pump water pump etc.Or it could have had a short block or long block installed which would reuse the accessories off of the old engine,or it could have had a good used takeout engine installed.Without any paperwork or repair orders to back up the "new engine" claim,it would appear to be a best guess scenario. You can use a loader with the setback axle,it will be a little harder on the front end,not quite as stable and will require rear wheel weights and or other ballast.
Mike Aylward
11-28-2007 15:54:43
 Re: 2440 with a new engine? in reply to MSM, 11-28-2007 07:32:42
The engine has been replaced at some time. The original engine would have been a 4219, not a 4039. Mike
