Yo Duane and others, Hot Coils Revisited Ive used the so called Hot Coils just on faith that they yield more spark gap energy, but like Duane, I have no proof or electrical evidence or even antecdotal evidence whatsoever they do. In order to measure what, if any, improved performance they offer, it would take some sophisticated electronic test equipment which the average Joe doesnt have. In addition, even if they did indeed allow for more energy to be discharged across a spark plugs gap, I seriously doubt a dyno test would show much HP increase. Furthermore, I doubt any human can ACCURATELY detect the difference to the point of proclaiming "Gee see how much better she runs with that hot coil" THAT ALL BEING SAID lets get down to the physics (Duane) and engineering (yours truly) of how a so called hot coil might produce more spark gap energy then a regular. OKAY if you change out the coil and alllll l else remains the same (which is basically true) the rotors magnetic strength dont change,,,,, ,,,,, ,the iron coil core dont change, you use the old one,,,,, ,,the air gap and laminations etc dont change,,,,, ,,,the RPM dont change. THESE ARE ALL (especially rotor magnetic strength and RPM) factors that influence the energy imparted into the coil by the spinning rotor..... Sooooo ooo it looks to me like for the so called Hot Coil to produce more energy it has to be the result of things like: 1) The wire used has less resistance per unit length so theres less heat energy loss. (higher quality wire) 2) The insulation used is thinner such that the wire is denser (more wire/coils packed in closer together) and resulting magnetic flux density is increased. (higher quality thinner insulation) 3) Similar to above, the closeness and density of wire n coils between the primary and secondary is improved which also improves the mutual inductive coupling from primary to secondary resulting in less losses. I INDEED BELIEVE SUCH WIRING AND INSULATION IMPROVEMENTS CAN RESULT IN A MORE EFFICIENT COIL..... Anyone disagree with that??? BUTTTTT TTTT to really see if the coil yields more energy to be expended across the spark plug gap (same gap as used before with old coil mind you) one would need to accurately measure the voltage x current x time of the spark. Then if the hot coil yields more energy, I guess as an engineer Id have to admit YES THEY ARE SUPERIOR Dont get me wrong, I use them on faith they are indeed superior and plan to continue, Im just saying it would be nice to see some hard core electrical proof of such cuz im convinced no human can reallyyyyy y tell the difference and doubt a dyno would show much, if any, HP change. Furthermore, I doubt even any vendors have access to any such real data, its the stuff ONLY the designers n test engineers at the coil company may have. NOTE I think our buddy Glen sent me some Wico literature which indicates the hot coils have greater inductance (makes sense if more wire or coil etc) and therefore if used one should also use a higher MF rated condensor (also makes engineering sense) which if I recall was the X 6916 ??? versus the standard condensor. Id have to dig out the notes when I gave my last Wico Seminar. TO MY SURPRISE when I asked some rebuilders at a show recently if they used the higher MF rated condensors when they installed hot coils, THEY NEVER HEARD OF SUCH and used the same regardless !!!!! !!!!! To me if the coil has more inductance, the condensor size should also be changed !!!!! !!!!! Duane, absent a conflicting seminar of my own, Im gonna be in the front row and looking forward to your mag seminar at GOG next March. I was forced lol to give it the last 2 or 3 shows n wanna see if I made any mistakes????? Although Im knee deep in theory, I havent repaired them professionally like you. See ya there Your thoughts on the above ????? ?? John T
