special expansion plug
joelrand
12-18-2007 05:30:16
Where can I find the special expansion plug that keeps oil from seeping around the belt pulley brake operating pin? This is on a 720 Diesel with the F2500 1st reduction gear cover. Deere says it"s obsolete. If it"s not available, what to do?
joelrand
12-18-2007 07:52:25
 Re: special expansion plug in reply to joelrand, 12-18-2007 05:30:16
This expansion plug has to have a hole in the middle for the operating pin to go through.
Mike M
12-18-2007 09:50:21
 Re: special expansion plug in reply to joelrand, 12-18-2007 07:52:25
Carefully try to remove it and reuse it ? Or like Frank said maybe drill a hole in a new one ?
F-I-T
12-18-2007 08:59:33
Maybe you can take a standard size for the OD, then drill a hole in the center to roll your own. The last part before the pass through plug is an o-ring, so if it's leaking, that's the problem. I doubt that the expansion plug will hold back more oil than the o-ring behind it.
Frank
F-I-T
12-18-2007 07:11:39
I have not had a chance to look, but certainly McMaster Carr would carry those. A NAPA of any age probably has an assortment of those button top caps.
Frank
