1946 D Oil system
John Boy
12-21-2007 04:52:21
I can not find enough information in the old responses here. My oil distrubution system plugged up or is not working on the right main side. I plan to remove all the lines and clean it out. I miss the advice I would get from Clooney as he has helped a LOT. Would someone how knows him say thanks again.
The after market manual is very limited. Is there a manual I can get for a D that goes into more detail? How do I adjust the oil pressure regulator?
Paul from MI
12-21-2007 09:50:04
 Re: 1946 D Oil system in reply to John Boy, 12-21-2007 04:52:21
Oiling system is pretty sim;ple on a D. If you are showing oil pressure (10-15psi) on hte gage, then a plugged line is about all that can keep on bearing from getting oil. Remove lines and clean them. Also check the rod bearings, if the passage in the crank is plugged oil won't get to them, but not a likely thing. Check the oil pipe to the valve cover thoroughly as it can sludge up easily. Adjust the oil pressure by rremoving the main cover, loosen the clamp screw on the adjustment screw and adjust as needed. It is located on top of the oil filter housing. Paul
John Boy
12-22-2007 12:32:47
 Re: 1946 D Oil system in reply to Paul from MI, 12-21-2007 09:50:04
When I last saw it run the needle was almost straight up on the oil pressure gage. My guess is the right side line is blocked. All the bearings on this side including the rod were dry. The left side was wet. I am replacing the main bearings, crankshaft, connecting rods so I want to get it right. I will take all the lines off that manifold on top of the oil fiter housing to prove I can get flow out of every port. I will also shoot oil down both main holes on the crank to see if oil comes out the journal holes too. I will tighten against the oil pressure adjustment screw some too as you suggest. Thanks for your help! Some times all it takes is a little confidence. I think what I might do as I get the crankshaft God willing back in the right timed spot I will put oil in the crankcase and turn it over to see if the oil pump will pump up oil to the crank journals. When I get the engine to run again I will check the oil pressure but then take the cover off to see if I am slinging oil off both rod bearings.
