JD 950 wont start
markster
01-01-2008 15:46:33
I recently purchased a JD 950. It's been sitting for about a year outside. The seller said it ran fine when parked. It turns over but doesnt start. Lots of white smoke out the exhaust, and it sounded like it maybe fired once. What should I check first? Any help troubleshooting is appreciated.
mark
markster
01-04-2008 14:13:59
 Re: JD 950 wont start in reply to Andy Motteberg, 01-01-2008 15:46:33
With a fresh battery and clean connections it started! Chugged a bit but soon settled into a nice purr. Thanks for the help!
markster
01-02-2008 14:54:34
Can I test the glow plugs with a multi-meter?
In a couple days when the weather warms up, Im going to clean all connections and try with a fresh battery. Thanks for the tips.
buck eye al said: (quoted from post at 19:28:17 01/02/08) Or the glow plugs may be burned out. It happens & they're 'bout like replacing little spark plugs though usually there are some "other" things in the way.
MSM
01-01-2008 22:43:49
 Re: JD 950 wont start in reply to markster, 01-01-2008 15:46:33
Did you cycle the glow plugs?
buck eye al
01-02-2008 14:28:17
 Re: JD 950 wont start in reply to MSM, 01-01-2008 22:43:49
PeterM
01-01-2008 17:01:49
Make sure the compression release handle is in . It is located below the dash on the left side.
RobMD
01-01-2008 16:24:50
It's trying to start. You need really good cranking speed. How's the battery and cables? The fuel could also have water in it. ANYTHING can happen to a tractor that is left outside.
