JD 950 hydraulics not working
markster
01-04-2008 14:21:32
After succesfully getting my JD 950 started after sitting outside for a year i found out none of the hydraulics work. It has a loader and a backhoe on it and I need to lift them to move it. It also has power steering which doesnt seem to be working. I checked the dipstick by the gear shifter when it was not running and the fluid appears clear and in the hashed area. Is that the correct way to check it? How do I troubleshoot this? All sugesstions appreciated!
thanks,
mark
leon
01-05-2008 05:47:15
 Re: JD 950 hydraulics not working in reply to markster, 01-04-2008 14:21:32
I'd suggest towing it into a warm area or waiting 'till the weather gets above freezing for a while before attempting again or the hydraulic pump could get ruined - if not already damaged.
RobMD
01-04-2008 14:42:52
Something's frozen in there. Could be condensation in the pipes and pump.
