newer crank in an unstyled A now piston ring trouble
36 A
01-06-2008 09:20:33
I installed a newer crank in my 36 A and with it i put the newer rods and pistons.Since my bores were so so, i used STD. cast late A gas high altitude pistons.The problem is that the bottom ring comes 1/2 way out of the back of the block and the top ring comes out 1/2 way at the ridge at the top of the bore. i also have .045 m/w and another set of just plane late A gas cast pistons and the rings all line up the same so they will all do the same thing.Now i was told that there was two differant m/w pistons.One with a big notch and one with a smaller notch and that i needed the small notch pistons.Dose any body know this for sure,i have know problem boring the block if it fixes my little problem.
BushogPapa
01-06-2008 20:44:30
 Re: newer crank in an unstyled A now piston ring trouble in reply to 36 A, 01-06-2008 09:20:33
That "Late" crank "stroked" it a 1/4" didn't it...!! Should not create too much problem, if you have the top ridge reamed and honed well enough.. You can "Massage" the notch to get good flame travel..
J Schwiebert
01-06-2008 10:17:11
Is everything good in the bore? If so I would clean the bore at the top and do allow for expansion as the piston will grow when it runs and I know there are some around here that do not run a lower (bottom ) ring. Less rings less friction, why do you thing the trend was to elimating all those rings?
Will P
01-06-2008 10:03:20
As far as I know, all oil rings come "half out of the back of the block" at the bottom of the stroke. At least my A B and G do.
Will
mikicic
01-06-2008 09:37:07
I assume you are pulling this tractor. you could just eliminate the top ring, and have a new groove machined for the oil ring above the old groove.
36 A
01-06-2008 11:44:42
 Re: newer crank in an unstyled A now piston ring trouble in reply to mikicic, 01-06-2008 09:37:07
well i looked at what i had laying around and Stds cast and m/ws have the bottom ring in the same spot.the top ring on the m/ws is differant if the notch is large or small.thats when i lined the rist pins up.So if i had a set of 045 with the big notch id be ok.But i have 045 small and 125 big notches, block is in nice shape dont need to go 125.
Kent Petersaen
01-06-2008 16:49:37
 Re: newer crank in an unstyled A now piston ring trouble in reply to 36 A, 01-06-2008 11:44:42
if you look at the spark plug hole you will see it gos strait in to block 90 deegres to piston. 49 and later A s it is at an angle this angle moves the tip of plug closer the head so you need pistions for 46 or earler the late piston will not fire correct luck Kent
