4020 conversion
4020 steve
01-15-2008 17:12:03
will a late model 4020 diesel head function on
a 4230 engine? I know they are both 404 and will
probably bolt up.They do have differant part numbers.I am putting a 4230 engine into a 4020. Does anyone have knowledge of the changes to
convert? thanks for any help.
powertech84
01-16-2008 15:58:02
 Re: 4020 conversion in reply to 4020 steve, 01-15-2008 17:12:03
4230"s aren"t bad starters if they have the right head gasket, and the engine"s are in good condition.
5020s rock
01-16-2008 01:13:36
i dont know about the heads, but the motor will work. i am doing one rite now. the trouble is up front--(hydraulic coupler,fan blades,radiator hoses,possibly alternator) we did one 10 yrs ago and used 4320 side rails to accomadate the extra length....i am not buying the rails this time. YES--THAT MOTOR WONT START FOR CRAP....i have heard people adjusting the advance on the pump or changing starters...we just use a touch of ether--lol. good luck
4020 steve
01-19-2008 18:35:41
 Re: 4020 conversion in reply to 5020s rock, 01-16-2008 01:13:36
In response to your fan and hyd coupler problem
i was planning to use my old 4020 balancer on the
4230 engine. The crankshaft number is the same at
least on mine.Also i was hoping to use the 4020
waterpump and block the waterport on the block.
that would solve the clearance issues.the only
question i have is would it make a hot spot or would it circulate the coolant enough? thanks
mjbrown
01-15-2008 17:26:30
I hope you are doing an overhaul on the 4230 engine so it will start as good as the 4020 engine. I have a 4230 and it is a poor starter and I guess they all were.
Gary in TX
01-17-2008 07:21:31
 Re: 4020 conversion in reply to mjbrown, 01-15-2008 17:26:30
I've got two 4230's and they start fine for me.
Great size tractor for hay work.
