Fuel Gauge Problem 2020 LU
regularguy
01-16-2008 11:31:18
I have a 2020 LU John Deere that has a problem with the fuel gauge, it seems that when I turn the key one click the fuel gauge works fine, but when I start the tractor it stops working, sometimes it comes back and works while it is running sometimes not. I can't find a loose electrical connection and I pulled the sending unit out and it appears to be okay. Should I replace the switch next? What about a circuit breaker issue, could that be the problem? Thanks in advance for your help.
