I posted here a week or so ago about our 720 that won't start. We drove it home one day from a show and it hasn't run since. At first we figured it was the convertor and was looking for a rebuild kit, no luck. Then we went ahead and ordered a new one, got it hooked up and still nothing. The fuel tank is low at about 12% but it has run with it being lower before. Friend of my dad's who used to work on LPG stuff said to make sure that the carb has suction to the convertor as it has to have some to make the valve or something work. Didn't have that or not much and dad put a kit in the carb, still nothing. Got a carb off of a 70 LPG that was running and tryied it as well with the same results, nothing. We have checked the timing and it seems to be doing fine. For some reason it doesn't seem to be getting fuel to the engine or maybe even not to the carb. WE know for sure we have fuel going to the convertor as you can turn the liquid on and see it coming out at the connection to he convertor. When we hit the button on the convertor to squirt fuel into the carb it doesn't make a sound or if it does it ia real faint. Seems I heard one once that when they hit the button it sounded like an aersol can being used. Dad says this is normal and I think not. Seems to be in time and like I said earlier it has a real good spark. any ideas and thoughts are greatly appreciated as my dad is about frustrated with the whole thing. Thanks!!!!! Any ideas on what to look for!
