JD 60 hydraulic pump HELP
kevin jd 60
01-21-2008 09:46:09
Just got this model 60 (1954-55)noticed a leak of fluid next to hydraulic pump/distributor housing. Power washed area, oil came right back.
I want to remove and replace gasket, WHAT WILL I HAVE TO BE CARE OF. if I undo the 6 or so bolts, unbolt fan shaft and hoses, lift out of position, what will happen...any advise or is it just as easy as remove, place and set back into place??? thanks
jdjack
01-21-2008 10:20:58
 Re: JD 60 hydraulic pump HELP in reply to kevin jd 60, 01-21-2008 09:46:09
Is the leak engine oil or hydraulic oil?
Where is the leak at?
Kevin JD 60
01-22-2008 08:49:44
 Re: JD 60 hydraulic pump HELP in reply to jdjack, 01-21-2008 10:20:58
Hydraulic/distributor house sits on top of trans case. Oil is coming from hydr side around seal that is between trans case and hyd/dis housing.
cant tell wha type looks like the 90 weight oil per the manual but cant be 100 percent..if i take this housing off trans case what will i find, i am afraid i will mess up some type of alignment of some gear or something...no problem?
thanks
