Best bang for the buck 2cyl Deere
2cyl curious
01-23-2008 17:19:19
I'm looking at buying my first johnny popper. What model should I look for?
John Van Valkenburgh
01-24-2008 18:40:18
 Re: Best bang for the buck 2cyl Deere in reply to 2cyl curious, 01-23-2008 17:19:19
I'm pretty fond of my 1953 model 50, but then again it IS mine...
The 50 is small enough to be reasonably economical but big enough to handle most jobs of a small farm. In the end the "best" fit for you depends on what you potentially will use it for.
There aren't any of the 2 cylinders that I'd recommend you avoid. They all have a unique personality once you get to know them.
John
1953 Model 50
buickanddeere
01-24-2008 16:55:00
Slant steer 420 or 430 if storage room is limited. 520 if you have access to a shed with higher doors. Purchases a complete and intact runner or wish you had.
jubilee johnny
01-24-2008 11:33:33
There are several things that are important. Are you looking for a running tractor that doesn't need much work or do you want to get a fix-er-up-er? If you don't know much about being a 2cyl jd mechanic YET, get one that runs well. Larry59 probably has as good a deal on one as you will find, especially since it has a loader. Do you need 3pt hitch? Do you want wide or narrow front? Do you like the styled or early models? What are you going to use it for besides hear that great pop-pop idle? I have a 70wf gas with a 45w loader and 3pt (from my grandad) which is my work horse. I have a 48b narrow front to pull wagons and small implements. We are restoring a 41H for parades. I have my grandad's 46d to restore later. Good luck and let us know what you do.
Larry59
01-24-2008 03:38:38
 Have 1951 John Deere A to sale in reply to 2cyl curious, 01-23-2008 17:19:19
I have a John Deere A style for sale. Needs painted and left front grill has some damage. Rest is fine. It also has a front loader W45 on it with a large bucket. I also have a front blade to replace bucket with that goes with it. Even in this bitter cold. It starts up good and runs along ok. Tires are good... I want 1600.00 only for it all. 573-378-2112 or email me at lawrence9309@sbcglobal.net I am in Mid Missouri USA
Indiana Boy
01-23-2008 19:04:48
Welcome to the wonderful hobby (habit) if collecting 2 cylinders. My first 2 cylinder was a late styled A (1950 model). I was very pleased with this as my first because it had good power, had hydraulics, and had electric start and lights. It is almost a necessity to have lights on at least one of your antiques-- you get aweful popular in the hayride season. The late A's also have almost any part available and they are very simple to work on. Don't worry, though, I'm sure that after the bug bites, there will be more green tractors to come. Good luck in your searches for the right tractor.
D-Man
01-23-2008 17:40:56
Curious, what are you going to use the tractor for? Parade, work on farm, restore it youself etc. What features would you like? Rockshaft, power steering, HP, RC? Too me they are all good in any variation but what are yous willing to spend? Do you have a price range? What features on the popper interest you as a hobbist? Once you can get a list together than one can give models or years. Just a common A is a good bang for buck. There cheap and many parts available. B series also. You can get 3 of them for 4000.
Christopher S.
01-23-2008 17:38:22
You can first narrow down to what model you want by what you plan to do with it. Do you plan on showing it and using it in parades. Or do you plan to use it to work with. The line of work you do will determine what model you should go with. If you plan on showing it, how are you going to transport it. The small model L will fit in most pickup beds but the larger G or R will require a 3/4 or 1 ton truck with a trailer. In my opinion any of the models are really neat and can be a great start to a tractor collection. If you are new to the two cylinder world it would be to my suggestion to get a late styled A or B that is in nice condition. Parts are pretty easy to find and they are fairly priced. That way you can fix small problems as they come along and can learn from them. If you get a basket case of a tractor from the beginning it can often be discoraging.
Christopher S.
01-23-2008 17:38:08
Christopher S.
01-23-2008 17:34:07
Den N Ms
02-14-2008 19:17:53
 Re: Best bang for the buck 2cyl Deere in reply to Christopher S., 01-23-2008 17:34:07
model B
Rusty Wheel
01-23-2008 19:34:10
Hey Christopher. All the two cylinders are great machines. I'd get some books and look at the different models and find one that apeals to you. Then consider what you plan to do with it. If you have help, then you're not limited to size and weight. If on the other hand you're planning on restoring it by yourself, then size might be something to consider, You can have just as much fun with a small one as a big one. The largest one I've restored is a 1951 "G"with not much help. I just finished a 40W. Really turned out nice. Which ever model you choose, I'm sure you will be much pleased with it. RW
