JD300 hydraulic oil change
markspark
02-06-2008 23:56:30
Do you have to bleed the hydraulic system of a JD300 backhoe after cleaning the screen and changing oil and filters?
The filters and screen were pretty dirty, so i hoped this would be the cause of the forward/reverser taking so long to engage.
It sat for a couple of months after i drained the oil because i had trouble finding filters.
Now i have nothing, no drive at all, no movement of the loader, digger or stabilizers.
Mark
raddlechain
02-07-2008 14:12:04
 Re: JD300 hydraulic oil change in reply to markspark, 02-06-2008 23:56:30
I'm sorry, but how in the world could you have had trouble finding filters?
jdemaris
02-07-2008 05:55:17
No, doesn't require any bleeding. If oil is getting to the front pump, and the pump is turning, the stroke-control valve is probably stuck open (if you have the US built 2.4 cube pump).
If the front pump is the little German pump, and there's a little hydraulic reservoir tank up front above the pump, try filling it and see if the hydraulics take off.
There are many possible causes - but all it takes is one little piece of debris to work through the system and get stuck undre the seat of the strokep-control valve and the hydraulics will go completely dead.
