JD 2010 Hydraulic Pump Lever
robersw
02-08-2008 10:05:20
I have a JD 2010 RU SN 48203. I was hoping someone could send me a picture of how the lever for disengage the hydraulic pump with clutch pedal is supposed to be setup. The tractor I bought did not have the original setup, it had zip-tie holding the lever up all the time, and there has been a lot of patch jobs done on the clutch pedal. I have ordered the new parts from Deere, but I would like to see someone's setup to make sure when I get the parts, they get installed correctly.
Thanks
Scott
robersw
02-11-2008 06:25:03
 Re: JD 2010 Hydraulic Pump Lever in reply to robersw, 02-08-2008 10:05:20
Just wanted to bring this back to the top in hopes someone with this tractor might be able to help me out.
Thanks
Kevin B
03-04-2008 22:13:32
 Re: JD 2010 Hydraulic Pump Lever in reply to robersw, 02-11-2008 06:25:03
I don't have a way to send you a good picture. I have a 2010 R and the parts for it are no longer available. However, there should be a bolt/stud above the lever that disengages the pump. A spring attaches to the lever and stud to hold the lever up and pump engaged. The push rod is notched and passes through the floor board. To disengage the hydraulic pump, with the engine not running, step down on the push rod and engage the notch in the slot of the floor board. When the tractor is sufficiently warmed, shut the motor off, reengage the pump and restart the motor. I've only had to use mine once or twice on the coldest days of winter.
