Help !! 2955 Clutch Problems
2955JD
02-20-2008 19:54:38
I have a 2955 with approx. 5000 hrs. Clutch was replaced less than 200 hours ago. I just replaced the clutch master cyl. due to the old one failing. Now I cant get all the air bled out.Any tricks to doing this? A I can get is about a half of a pedal.
Thanks in advance
Chris
2955JD
02-22-2008 20:42:27
 Re: Help !! 2955 Clutch Problems in reply to 2955JD, 02-20-2008 19:54:38
i can not get the clutch pedal to come all the way back out....it only wants to come out 1/2 way thanks for all the help and ideas
ben brown
02-21-2008 17:48:24
what i do is take a clear plastic line hook it up to bottom bleed screw run it back up to the resvior then pump the clutch peddle...A lot of time the air bubble well be in the line from resivior to master cly. where it is lower then the master cly. also crack the line where it comes off the back of the master cly.
grwrench
02-21-2008 16:18:06
hello, these are not easy to bleed, however i have found, if you nose the tractor down hill quite often you can pump the pedal and it will come right up. if that don"t work we use a pump oil can filled with brake fluid, DOT 4, by the way, attach a clear piece of plastic tubing to oil can and bleeder screw, open screw and pump the fluid reverse flow into reservoir, works EVERY time. 40 yr. JD VET. GRWRENCH
powertech84
02-21-2008 15:33:57
if i remember right these actually have two different bleed valves.
R. John Johnson
02-21-2008 04:46:48
What kind of brake fluid did you use in the clutch? If you use the wrong dot number, it is made of a different base fluid and will destroy the seals in the clutch master and slave cylinders. Can't remember which number it is without looking in the manual.
John
2955JD
02-21-2008 07:23:33
 Re: Help !! 2955 Clutch Problems in reply to R. John Johnson, 02-21-2008 04:46:48
I used the fluid that JD sold me...
Jake Winn
02-21-2008 13:19:44
 Re: Help !! 2955 Clutch Problems in reply to 2955JD, 02-21-2008 07:23:33
These are a pain in the butt to do. Do you have a vaccum pump for bleeding brakes, I have found that to be helpful. Also i have had a couple that i needed to adjust the linkage on the pedal to make sure all is correct due to wear. Do you have a tech manual? This is very important to have the correct adjustments for the clutch pedal rod and stop.
good luck
