power adjusted wheels
123 farmer
02-23-2008 10:40:34
I have a 4010 with the power adjusted wheels but i can not move wheels in or out becasue the sprockets that go in the hub are missing. is there a way that i can put these sprockets in without pulling everything off the axle.
long green line man
02-24-2008 13:49:41
 Re: power adjusted wheels in reply to 123 farmer, 02-23-2008 10:40:34
JD power adjust wheel (with locking collar off) are moved in or out by moving tractor forward or backward, while steping on opposite brake. What you have is rack and pinion ajust,you should be able to move half way off end of axle, hold with loader or car engine puller & chain, pull out wedges replace gear, reasemble.
