hey, nice rack
joelrand
02-28-2008 11:57:26
I'm getting ready to start my 720 diesel for the first time. I'm uncertain how to set the rack adjustment to 13. I see ridges on the rod, but no numbers and no pointer for reference. Any tips?
Mike M
02-28-2008 12:45:57
 Re: hey, nice rack in reply to joelrand, 02-28-2008 11:57:26
Well there is to be a pointer on the side of each pump assy. It is held on with a screw and many have washers under them from being adjusted to match each other. I can't totally recall ? but if you have no numbers there should at least be a larger line at like numbers 5 and 10 etc. just count the lines each one should be equal to 1 rack setting. And if it is out of adjustment the adjusting screw is behind a welch plug or freeze plug on a piece that bolts to the left side of the block.
