36 B rear axles seals and felt washers
Jeremy B
03-10-2008 10:44:22
I pulled the rear axles out on my 36 B to replace the inner seals. When I pulled out the axle,the bearing, felt retainer and bearing spacer all came out together on the axle. Do any of these parts press on the axles or is it just stuck from old grease and years of use. I got new felt and inner axle seals any tips for when I reassemble.
Jerry Pevehouse
03-10-2008 12:57:38
 Re: 36 B rear axles seals and felt washers in reply to Jeremy B, 03-10-2008 10:44:22
Most of the time you can seperate them just fine, but be careful as not to damage them. You might have to resort to heat if they are too tight of a fit to get them apart. When going back with it, use care as well if you don't want to damage the sleeve.
