turning brake drums
1951g
03-13-2008 08:15:26
Does anyone know where I can get my brake drums turned for an unstyled A and B? My local guy here says he can't because of the shaft that's riveted onto the drum. He said we could cut those off and then he could but I really don't want to do that because I don't know where I could get more rivets that would look correct like the originals. Thanks for any help.
Mike M
03-13-2008 10:47:29
 Re: turning brake drums in reply to 1951g, 03-13-2008 08:15:26
If your drums are tight to the shafts DO NOT remove them !!!!! If they are loose you can pound them tighter , but if really loose you will need to go oversized.
I have turned them before in an ordinary lathe chuck the end of the shaft and use a live center in the drum end that is center drilled you have enough length on that shaft to work in the middle.
teddy52food
03-13-2008 09:58:44
Find someone with a good turning lathe and turn them with the shaft. Then you will know for sure that they are centered.
Kurt_JDB
03-13-2008 08:35:48
I think John Deere still sells the rivets.
Kurt
1951g
03-13-2008 08:43:01
 Re: turning brake drums in reply to Kurt_JDB, 03-13-2008 08:35:48
Thanks for the response Kurt. I'm wondering though would you need a special tool to put these rivets on with and also how much they would cost?
