JD GASKET SET?
Sorno
03-13-2008 09:26:14
1. I was wondering what gaskets are left out of a "full" gasket set?
2. Where is the best place to get a complete gasket set?
FYI I am working on a 70 gas. I have the whole block out all the way down to the crank case. Is there a kit that includes the gaskets for the tractor crank case as well?
Sorno
03-14-2008 09:48:00
 Re: JD GASKET SET? in reply to Sorno, 03-13-2008 09:26:14
HOLY SMOKE!!!!
From Olson Gaskets:
[quote:3660885658]We do carry the overhaul gasket set for $324.50.[/quote:3660885658]
Are these made out of gold?
What does Olson have that these don't?
$62.69
Part Description & Parts Included
John Deere 70 Full Gasket Set
Full Gasket Set: This is a complete engine rebuild gasket set. It contains all of the necessary gaskets such as the head gasket, valve cover gasket, intake & exhaust manifold gaskets, oil pan gasket, front & rear crankshaft seals. It may also include a number of miscellaneous gaskets such as water pump and oil pump gaskets and o-rings. Please be sure to view the image to see what gaskets are included. Some gasket sets will not include certain gaskets such as crank seals, valve cover gaskets, valve stem seals. This is because those gaskets may only be available through an OEM supplier.
deeredv
03-14-2008 08:33:06
Try NAPA,They have sets for JD A"s .Should have the for your 70 at a fraction of the cost of Deere.Deere is getting outrageos on their prices.
Mike M
03-14-2008 07:18:06
In the back of a JD parts book those sets are listed,illustrated,and itemized as to what is in them. JD may still sell them.
Sorno
03-14-2008 06:27:09
 Re: JD GASKET SET? in reply to Mike w J, 03-13-2008 09:26:14
robersw said: (quoted from post at 14:20:05 03/14/08) Also, here is a link from a real quick search on the net.
Good Luck
Link
Thanks,
Have you gotten a set of these gaskets from olson's? can you tell me what was missing, if anything?
robersw
03-14-2008 06:20:05
Good Luck
http://www.deerelydeparted.com/p-380-john-deere-gasket-set-for-engine-overhaul-on-model-70-gas-tractors.aspx
robersw
03-14-2008 06:17:40
Link
Olson's Gaskets
3059 Opdal Rd E
Port Orchard, WA 98366
U. S. A.
phone/fax: (360)871-1207
Hours of Operation: Monday - Friday 8 -5 (Pacific)
E-Mail: info@olsonsgaskets.com
charleslendman
03-14-2008 06:14:46
Just google olsons or olsens gaskets
Sorno
03-14-2008 05:41:04
 Re: JD GASKET SET? in reply to Jake Winn, 03-13-2008 09:26:14
charleslendman said: (quoted from post at 19:39:21 03/13/08) Try olsons gaskets in Calif i believe
Do they have a phone number or website I can look to?
Have you gotten sets from them before?
charleslendman
03-13-2008 11:39:21
