49 A transmission problem
1936
03-17-2008 05:50:20
Just stopped moving. No forward or reverse gears or PTO. When it happened no noise not under pull just driving on the road. Turned into a stationary engine. Looked at my parts list manual and decided to see what I can learn here.
Resting Relics 1
03-17-2008 06:23:02
 Re: 49 A transmission problem in reply to 1936, 03-17-2008 05:50:20
1936, Could have lost the spline on the clutch drive hub. Should't be to hard to find such a catostrafic failure. Has to be a broken drive shaft or stripped spline on the input end. I guess I would start with pulling the clutch and proceed to the reduction cover and see what you find. John
Lee B
03-17-2008 06:02:42
First thing to look at would be the input gear in the large gear case on the right side of the engine. The same one that houses the clutch. It sounds like the gear fell off of the input shaft and is laying in the bottom of that big case doing nothing.
Somehow the gear got past a big ol nut and a bearing in order to jump off the input shaft like that but I found mine about halfway AWOL when I just happened on it a few years ago.
