Do what you want - but the pump will work fine with cold starting at almost zero transfer-pump pressure as long as the static timing is set correctly. It was one of many issues that Deere suspected with starting problems with 40-series tractors. On a few it was true, with most it had nothing to do with the problem. You can buy brand new starters for around $150. Direct drive and gear reduction. Keep in mind that gear reduction starters will usually crank better in cold weather and can do it with a smaller electric motor - so the motor amp-draw is not always a good figure to use. Deere originally used 700 amp and 900 amp ratings on direct-drive starters. When they started getting rated in watts or kilowatts instead of amps, it kind of lost me. My 7.3 diesel in my Ford truck has a 3000 watt starter and works great. My 6.2 diesels have 2700 watt and 3500 watt GR starters - going by their ratings - and all work fine. Try DB Electrical - that's where I've been buying. They are in Tenessee and you can call if you want specs. 1-800-753-2242 Link A>Link new gear-reduction starter - Nippondenso style OSGR 2.7 kW, 12 Volt, CW, 13-Tooth Pinion is $140. A new direct-drive Bosch/Delco syle is $150 new. It fits the following and more: John Deere Tractor - 820VU, 1020, 1030, 1040, 1065, 1068, 1075, 1085, 1120, 1130, 1140, 1520, 1530, 1630, 1640, 1830, 1840, 2020, 2030, 2040, 2120, 2130, 2140, 2150, 2155, 2240, 2440, 2510, 2520, 2550, 2555, 2750, 2755, 2840, 2855N, 2440, 2550, 2555, 2750, 2755, 2840, 2855N, 2940, 2950, 2955, 3040, 3055, 3120, 3130, 3140, 3150, 3155, 3255, 6100, 6200, 6300, 6400, 830, 920, 925, 930, 932, 935, 940, 942, 945, 952, 955, 965, 986, 975, 5200, 5300, 5400, 5500
