401b not pulling
jjonas
03-22-2008 10:00:07
Hi everyone, My friend has a 401b that will not pull at all, will not move at all. I am not real familiar withh the trans on this tractor so please be easy. I pulled the shifter cover nad found no worn shifter parts, but did notice the top shaft looked to have slid rearwatd in the trans . the shaft had a keyway in it is this normal? The shaft went into what appeared to be a clutch pack, what is this for? Also when the clutch pedal is pushed down it makes a grind ing sound siniliar to a bad throw out oe release bearing. Any ideas or suggestions will be helpful. If additional information is neded please let me know Thank you for your time in advance jjonas
matthies
03-22-2008 17:07:14
 Re: 401b not pulling in reply to jjonas, 03-22-2008 10:00:07
If the tractor has a reverser, check the clutch linkage under the tractor to see that it is moving freely, some of these tractor have alot of adjustments to the clutch with a reverser. And with the reverser there are also oring ports on the top of the clutch/reverser valve under your right foot plate to check foward and reverse pressures.
johns48jdb
03-22-2008 13:06:46
what is a 401b. a dozer i'm guessing. sounds like yo should have started on the clutch first. the throw out bearing may have been riding on the clutch fingers and wore them off. the clutch may have worn down so far that the pads have come off of it. i beleieve that i'd look at the clutch side of things before you go any futher.
cannonball
03-23-2008 05:53:54
 Re: 401b not pulling in reply to johns48jdb, 03-22-2008 13:06:46
A 401B is about the same as a 2440...they were made till 1981...
MAY GOD BLESS THE USA
