410C low power at all rpm and black smoke at hi rpm
Hillbilly-tn
03-29-2008 19:25:29
Would hardly pull in 4th so I turned up the pump a little.It is still weak and it smokes at 2000 rpm and above. New motor and kit in pump. Is the timing off or low fuel presser.It needs more fuel at lo rpm and less at hi rpm.
thinks
Hillbilly-tn
03-30-2008 11:38:51
 Re: 410C low power at all rpm and black smoke at hi rpm in reply to Hillbilly-tn, 03-29-2008 19:25:29
Pump is set with a little advance. If I advance more it is hard to start. Not sure how timing advance works on pump.
wilamayb
03-30-2008 09:01:45
Sounds like you do need to check your timing. It sounds like it could need a little advancement. I'm sure your manual covers R&R of injection pump. There is no better source than the JD service manual. The product engineers wrote the manuals!
I suppose you may already have, but have you checked for air restriction? Air filter, tubing, etc...?
