2840 Clutch pack
jjamna
04-12-2008 18:21:53
My cousin needs a Hi-Low clutch pack for a 2840 J D Does anyone have a parts tractor with one they would like to sell.
Thanks
Jeff
buickanddeere
04-17-2008 08:53:10
 Re: 2840 Clutch pack in reply to jjamna, 04-12-2008 18:21:53
Your cousin should get the operators and service manuals from 1-800-522-7448 before he wrecks anything else while working on it.
Jeff McBride
04-17-2008 19:39:10
 Re: 2840 Clutch pack in reply to buickanddeere, 04-17-2008 08:53:10
I was there today and He said he had manuals (but can't find them)
I agree with you totally, he should have known not to pull start it. He has a 4630 and a 4240 also so you would think he would know better. I don't know for sure but my guess would be he pulled it with the 4630. Something had to give and it did, about 4 thousand dollars worth. All I can do is try to find him the parts and stand back and shake my head.
He is making a list of part #'s and we are going to try that route, fixing the one he has.
Do you know how much the clutches are?
jjamna
04-16-2008 19:47:41
Yes to the pull start. It is my Cousins tractor and he tried to pull start it. He has found one rebuilt and one from J D ( i assume it is rebuilt) for 4 grand. He wanted me to post and try to find something cheaper. He has his mind set on fixing this one and I will have to agree. Put 4 grand in this one and know what you have or spend 8 to 10 grand and may still have problems. Thanks for all the replies.
ben brown
04-13-2008 16:52:06
i had to replace the complete two speed in 4440 last fall the two speed complete rebuilt from mo. tractor was double DD in siekton mo was 1750.00 . if it just need the disk. then replace them might have to also do the metal along with the fiber coverd one they have been up dated to some sorta meteal fiber disk. also replace the sealing rings. and piston rings. a parts brake down well help. its not that big of deal to rebuild. one thing you can count on is if its man made it well in time wear out or break most likey it just time to be rebuilt.
buickanddeere
04-13-2008 12:44:51
Link
Can't recomend all the time, money and work of obtaining a donor tractor, removing the clutch pack then installing that worn out clutch pack into another tractor.
What ruined the clutch pack in the 1st place? No use replacing parts if the casue isn't located. It takes less time and costs less $$$ to solve the problem rather than repair the symptoms.
If you look in the 2840 parts listings. That clutch pack is also common to the 3120,3030 & 3130.
New parts from Deere are not all that expensive.
Being that the 2840 is around 28 years old. Depending on the condition of the rest of the tractor. It maybe time to trade or scrap it and get something newer/better. If somebody had dumped sae 90 gear lube or an economy hydraulic oil that doesn't say "wet clutch compatable" on the container. The pto clutch and brakes are also damaged. Low apply pressure will smoke the linings. Put a gauge on there and find out what is going on.
John Deere - Parts Catalog
Catalog: 4160 | Grid: 1H15 | Section: 50 | Page: 10
Catalog Name: 2840 Tractor
Page Name: HI-LO CLUTCH KEY PART NO. PART NAME QTY TRACTOR SERIAL NO. REMARKS
1 19H1813 CAP SCREW 9 5/16" X 5/8"
2 R44157 COVER 1
3 19H2729 CAP SCREW 3 5/16" X 4-1/4"
4 R39260 PLATE 1
5 RE227812 CLUTCH DISK 9 (SUB FOR AR39128)
6 R39259 CLUTCH PLATE 10
7 R44156 HUB 1
8 R39299 SNAP RING 2
9 R39282 DISK SPRING 9
10 R39280 PISTON RING 2
11 R39285 PISTON 2
12 R39304 WASHER 2
13 R44160 BUSHING 1
14 R56457 DOWEL PIN 2
15 H871R BALL 3 5MM (3/16")
16 AR91280 PLANET PINION CARRIER 1 (MARKED R58211 OR R70078) (SUB FOR AR69935 AND AR85745)
17 R65390 THRUST WASHER 2 (SUB FOR R39193) (SUB R278348)
18 R58210 PLANET PINION 1
19 R54961 THRUST WASHER 6
20 JD9932 NEEDLE BEARING 6
21 R58208 PLANET PINION 3
22 R58209 WASHER 3
23 R58212 PIN 3
24 H871R BALL 3 5MM (3/16")
25 R39276 BUSHING 1
26 AR57195 SHAFT 1
27 R26753 RING 2
28 R56457 DOWEL PIN 2
29 AR45379 DRUM 1
30 R39252 BUSHING 1
31 R65392 WASHER 1 (SUB FOR R39281) (SUB R278349)
32 R39265 BUSHING 1
33 R34650 SEAL 1
34 AR45376 SHAFT 1
35 B2641R DOWEL PIN 1
36 RE227810 HIGH-LOW CLUTCH 1 (SUB FOR AR69932 OR AR99256) (ALSO ORDER AR91278 AND AR99259)
37 R73701 WASHER 1 (SUB FOR T25409 OR R65391)
38 L29343 BUSHING 1
39 AR82795 SEAL 1 (SUB FOR AT27728)
40 JD10107 BALL BEARING 1 (SUB FOR AL28037)
Mike M
04-13-2008 16:37:34
 Re: 2840 Clutch pack in reply to buickanddeere, 04-13-2008 12:44:51
Or maybe they pull started it ? That will tear out a hi-lo
