45 A Flywheel Cover
jjamna
04-19-2008 12:51:33
I told you guy's I would have a lot of ?'s. I don't even have it home yet and have two.
#1 Do the 45 electric start A's have a flywheel cover? I don't have the tractor here yet so I don't know if it has bolt holes or not. It don't have a cover.
#2 It is an Allfuel tractor and I have never delt with one of these. I don't plan on running on anything but gas so do I just put gas in the big tank and go Putt Putt or what?
jjamna
04-19-2008 19:07:58
 Re: 45 A Flywheel Cover in reply to jjamna, 04-19-2008 12:51:33
Is the band that covers the gear teeth hard to find? I don't like the idea of the flywheel turning with them starter teeth just waiting to eat me.
JD @ Antique Acres
04-19-2008 20:20:15
 Re: 45 A Flywheel Cover in reply to jjamna, 04-19-2008 19:07:58
They can be found. They also are being reproduced. If I remember correctly Detwilers had them listed.
garytomaszewski
04-19-2008 18:55:14
No cover just a band over the ring gear. When we were using these the small tank was used for a reserve to save a long and embarassing walk from the far end of the field.
Deere Breath
04-19-2008 18:53:22
As to your questions # 1 not a cover as such but it should have a band that covers the ring gear on the flywheel to keep fingers clothes and lots of other things out of harms way. # 2 you can put gasoline in both tanks and use the small one like the reserve on a motorcycle. P.S. I grew up on a 1945 A and my grown son has it now.
JD @ Antique Acres
04-19-2008 18:46:20
While it doesn't have a cover, it does have a guard which covers the exposed starter ring gear.
jjamna
04-19-2008 18:19:33
Thanks Hoss
Hoss in Me
04-19-2008 17:38:56
1.No 2.yes Later ,Hoss
