Center Line of Draft.......one bottom plow ??
LittleD
04-21-2008 18:10:57
How is the center line of draft calculated when using a "one" bottom pull type plow???
A freind has one that wants to plow sideways.
Thanks, Rich
JMS/.MN
04-22-2008 09:01:51
 Re: Center Line of Draft.......one bottom plow ?? in reply to LittleD, 04-21-2008 18:10:57
Line of draft is one-fourth the width of the bottom, to the left of centerline of cut. Thus, on a one bottom 16 inch plow, 4 inches to the left of center.
Brian Bell
04-22-2008 04:50:41
See the link. The first 2 paragraphs should provide some insight. This was written in regards to a mounted plow, but I suspect the principle is the same for a mounted or pulled type plow. This is borrowed from a few gents over on the N board.
