Wheel Weight ...research
LittleD
04-25-2008 14:08:56
How would I reseach the following weights to find what they were used on? All John Deere weights.
H78062.....JD
M80071.....JD
M1168T....JD
H80070....JD
thanks, Rich
LittleD
04-26-2008 05:11:19
 Re: Wheel Weight ...research in reply to CLW, 04-25-2008 14:08:56
Mike,
I was so focused as to what (tractor) they fit ...I forgot the other use's they had for the weights. I think you're onto something.
Thanks, Rich
jd51mt
04-25-2008 15:35:58
 Re: Wheel Weight ...research in reply to LittleD, 04-25-2008 14:08:56
M 1168 T is the number for the front weight used on the model "M" series tractor. I think it could also be used on some model 40's. Try and get a back issue of Two-Cylinder Magazine March/April 2006. It has wheel weights listed in it.
MIke
MSD
04-25-2008 17:24:55
 Re: Wheel Weight ...research in reply to jd51mt, 04-25-2008 15:35:58
Where did you come up with those numbers? I have a pretty complete listing for the weights and the only one I could find was the M1168T which as jd51mt said fits the M series and the 40 T.
LittleD
04-25-2008 18:05:03
 Re: Wheel Weight ...research in reply to MSD, 04-25-2008 17:24:55
MSD,
The numbers came from JD wheel weights that I found. All JD weights. All weights are smaller than weights for the G"s thru the 730.
The H78062 are two piece weights.
My JD (M) parts catalog shows M168T for the front wheel...is M1168T a varition of the M168T ..?
Thanks, Rich
Mike Aylward
04-26-2008 04:31:09
 Re: Wheel Weight ...research in reply to LittleD, 04-25-2008 18:05:03
LittleD, without looking at a parts book, the weights with the "H" prefix are probably combine rear wheel weights. The "H" prefix normally is a Harvester part or was first used there. Hope this helps. Mike
MSD
04-26-2008 08:35:07
 Re: Wheel Weight ...research in reply to Mike Aylward, 04-26-2008 04:31:09
Didn't they have some for disk plows also that were two piece? I too was just thinking tractor weights.
Wilamayb
04-26-2008 09:23:41
 Re: Wheel Weight ...research in reply to MSD, 04-26-2008 08:35:07
Ive never seen a two piece, but I have seen a single piece weight on disc plows as well as pie weights.
