36 B front pedestal question
Jeremy B
05-02-2008 10:54:45
I am getting ready to put the pedestal back on my 36 B tractor. The pedestal has been off my tractor for probably 25 years. The surface that mates to the front of the frame is pretty rough and flaking off but I don't know was that surface machined flat when it was new or just cast flat. Mine laid on the ground in a barn for 25 years and thats why its rough but everything else about it is good. I want to make sure it goes on straight when I put it on.
Greenday
05-02-2008 13:30:41
 Re: 36 B front pedestal question in reply to Jeremy B, 05-02-2008 10:54:45
I just finished restoring a 36 B and YES the two mating surfaces are machined flat! Just be sure to get all the loose material cleaned off before you install the pedestal. If you dont as the rust loosens up and falls out the nuts will get loose.
RobMD
05-02-2008 11:01:54
Just cast flat. What I would just do is wire wheel these surfaces really good and then prime them, slap 'er right on that frame. No worries about irregularities.
