rought 3pt
jlong
05-07-2008 05:02:06
What would cause the 3pt to be really jumpy when trying to slowly raise on a 620. When lowering it is very smooth. Does not seem right.
GeorgiaHayFarmer
05-07-2008 17:34:34
 Re: rought 3pt in reply to jlong, 05-07-2008 05:02:06
Did you check your hydraulic fluid level? When checking the level, did you check while the lift is up or all the way down?
Scott
Mike M
05-07-2008 07:18:33
Some things that come to mind to check are, does the hitch stay up when shut off ? if the piston o-ring is leaking off this may cause some problems. There may also be some adjustments that can be done. JD has a very nice service manual on those custom power-trol units and it likely has a trouble shooting section.
jlong
05-07-2008 09:44:37
 Re: rought 3pt in reply to Mike M, 05-07-2008 07:18:33
Yup I have a manual at the house but it seems like the board always gives a good direction to start.
It just seems that no matter how slow I try to raise it it jumps 2 or 3 inches each time it comes up.
