430 With problems
330deere
05-16-2008 09:08:17
I have a 430 that after running for a couple of minutes start slowing down slowly until the motor dies. It starts up and runs great until it starts slowing. We thought it was a fuel flow problem but that isn't the case. Any help would be appreciated!!!!!
Gerald J.
05-16-2008 10:33:57
 Re: 430 With problems in reply to 330deere, 05-16-2008 09:08:17
Could still be fuel flow if you haven't checked and cleaned or replaced the screen in the carburetor inlet that is part of the inlet adapter.
Otherwise could be gas tank vent or a failing coil or condenser. 12 volts on a 6 volt coil is one way to make sure the coil fails this way.
Gerald J.
