New Gen Row-Crop Tractors; Late vs. Early PTO Engagement
powerhouse
05-16-2008 10:44:24
My late 4020 PTO appears to be either on-off. As you move the lever the PTO engages at a certain point, and it engages without any "slippage". My dad's early 3020 seems to engage more smoothly when you move the lever... a lot easier on downstream gearboxes.
Is there anything behind this? PTO clutch wear? Internal pressures? Or is this just the nature of the machines?
Glen D Anderson
05-16-2008 14:36:10
 Re: New Gen Row-Crop Tractors; Late vs. Early PTO Engagement in reply to powerhouse, 05-16-2008 10:44:24
Our '72 4020 utilizes hydraulic pressure to activate the PTO release bearing and requires a far more gentle hand to engage smooothly than the mechanically operated release bearing on our '69 4020 or 3020.
It can be feathered, it just takes more finesse.....
alabamafrog
05-16-2008 13:20:28
We have an early syncro 4010 and 4020, both have the clutch for the PTO just like the main clutch it can be slipped as gently as I want.
thurlow
05-16-2008 11:48:53
Hydraulic vs. mechanical
Rooster from Pa
05-16-2008 11:18:23
The pto engagement one the power shift models more on or off where the sinker range is more of a smoother ingagement. I hope this is some help.
