Help!!!!!!!!!
L M Hydraulics
05-21-2008 12:33:00
I am the secertary at my husbands hydraulic company. They got in this mower today and have spent all day looking at it talking but getting nowhere on what they needed to know..... .so being a woman I have no problem asking questions.....kinda like directions! :lol: Its a John Deere F935 Front deck mower and the hydraulic cylinders are appearantly not working the questions I have are as follows....1 where do u check the hydraulic cylinders for fluid?.....2 How much fluid should be in there? ..... 3 What type fluid should be used for proper function?
L M Hydraulics
05-28-2008 08:37:07
 Re: Help!!!!!!!!! in reply to L M Hydraulics, 05-21-2008 12:33:00
do you know where we can get some diagrams for this tractor? all the ones i have found must be purchased to be seen.
L M Hydraulics
05-22-2008 12:00:42
Thanks..... .he said he has done all that and still nothing working. :(
L M Hydraulics
05-22-2008 06:47:35
Ok more questions..... ....The hydrostatic transmission works randomly and the hydraulic lifts wont move and idea what could be causing this?
F-I-T
05-22-2008 11:39:59
 Re: Help!!!!!!!!! in reply to L M Hydraulics, 05-22-2008 06:47:35
I would first replace the main hydraulic filter that is a large screw on type canister filter that sits horizontal sticking off of the main transaxle unit. Part number AM39653, about $8.00 at your local Deere dealer. Since you have some hydraulics, the filter could be mostly clogged. Cheaper to replace it and know it is fresh than anything else. I've never seen one that clogged, but I don't know the condition of the machine. If that model has wet brakes, as the brake pads wear they can produce debris that can clog the filter with dusty strings. Also, look around the return lines for an inline screen, called a strainer. The tractor type hydrostatic units have one at the intake to the pump, but I can't say for a F935. The parts book does not show one, but I might be looking in the wrong place. It's unfamiliar territory for me.
HTH
Frank
L M Hydraulics
05-22-2008 05:33:16
Thanks! You should have seen the look on my husbands face when I told him this..... then I showed him! PRICELESS!
L M Hydraulics
05-21-2008 16:00:13
Thank You! How much fluid should be used?
JoeM(GA)
05-21-2008 14:22:43
After he scrapes the crud off the transmission pump, he should see a clear piece of tube in the "c"shaped bracket. Fill to above the clear section. John Deere H20C "hygard" is the fluid
third party image
Joe M(GA)
05-21-2008 16:55:53
 Re: Help!!!!!!!!! in reply to JoeM(GA), 05-21-2008 14:22:43
it should be about 4 1/2 qts
