1020 messed up
Ward
02-28-2000 15:25:35
Oh, boy! She's blowing antifreeze out of the breather tube on the valve cover. None in oil!! Cracked head?? How come no antifreeze in oil?? Gas engine..... Any ideas????
twopop
02-29-2000 06:16:44
 Re: 1020 messed up in reply to Ward, 02-28-2000 15:25:35
YOU DONT HAPPEN TO BE USING SYNTHETIC MOTOR OIL? WATER IN THE OIL WILL NOT TURN THE OIL WHITE LIKE IT WILL WITH REGULAR MOTOR OIL.LOOSEN THE DRAIN PLUG AND CAREFULLY CHECK FOR WATER,IT WILL COME OUT FIRST.YOU COULD HAVE A CRACKED HEAD,BLOWN HEAD GASKET OR A CRACKED BLOCK.I THINK ITS A BLOWN GASKET
twopop
02-29-2000 06:15:32
YOU DONT HAPPEN TO BE USING SYNTHETIC MOTOR OIL? WATER IN THE OIL WILL NOT TURN THE WATER WHITE LIKE IT WILL WITH REGULAR MOTOR OIL.LOOSEN THE DRAIN PLUG AND CAREFULLY CHECK FOR WATER,IT WILL COME OUT FIRST.YOU COULD HAVE A CRACED HEAD,BLOWN HEAD GASKET OR A CRACKED BLOCK.I THINK ITS A BLOWN GASKET
