1935 A Cracked
JDBob
02-29-2000 05:12:48
Any of you guys have any experience with a head that has been cracked where the lower radiator pipe attaches? This one has a small crack in it, and I was wondering how successfull I would be if I had it welded up? Where it is at it shouldn't affect bolting the lower pipe back on.
It also has a crack in the bottom radiator tank, I would think it could be welded and be OK.
Thanks
JDBob
bill
05-30-2004 17:35:58
 Re: 1935 A Cracked in reply to JDBob, 02-29-2000 05:12:48
after removing my 1935 jd radiator for some restore work I found it had been welder along the bottom .and it seemed to be holding ok.
Mark
03-01-2000 06:09:28
I've had the entire bottom cracked out and successfully welded it back in. Be sure to grind the crack in a V and use nickel #99 rod.Will last a lifetime.
