2 furrow JD plow
Robert
03-01-2000 11:50:04
I have just restored my grandfathers 1942 B but also found this old 2 furrow plow in the fence row. I am restoring it also. I'm assuming he bought it around the same time as the B (he bought it new) What model could this plow be? What can I look for to give me a clue. Your help is appreciated. This tractor was bought in Grimsby Ont. Canada
Hinckley Joe
03-01-2000 18:52:38
 Re: 2 furrow JD plow in reply to Robert, 03-01-2000 11:50:04
I think if my mind dosen`t fail me thair is a number stamped on the top of one of the beams also a logo. try steel wool or scotch brite and it may bring it out so you can read it.
mark
03-02-2000 16:12:08
 Re: Re: 2 furrow JD plow in reply to Hinckley Joe, 03-01-2000 18:52:38
The # on top of the beam will only be a part #. If it was bought the same time as the tractor it is probably a #44 on a 16 inch frame. Steel wheels the same size is probably a #52. A large land wheel and small furrow wheel is a #4. The 3 most common plows.
Robert
03-03-2000 05:54:52
 Re: Re: Re: 2 furrow JD plow in reply to mark, 03-02-2000 16:12:08
Thanks guys The plow has steel wheels the same size so I guess that narrows it to a #52 Thanks for the help . Robert
