BR gearcase oil
Joe Green
03-10-2000 11:02:14
I'm redoing a 1947 BR. Where do I put oil into the gear case? There are 2 levers on the gear case, each with a numbered shift pattern. One has 4 positions clearly marked 1,2,3,4. The other is clearly marked R,1,2,3,4. Does this tractor have 16 speeds forward and 4 in reverse? It isn't running yet so I can't try it out yet. I didn't know JD made anything with that many gears back then. Was the battery box originally up on wooden blocks? Thanks.
