John Deere H oil problem
Jerry
03-24-2000 17:50:05
I recently purchased a 1941 JD "H". It reportedly had set for two years undercover in a shed.It had not been started during that time. It starts fine but smokes a great deal. Other than rings or bearings does anyone have anyother input what might be causing the problem. Thanks, Jerry
Paul from Michigan
03-24-2000 19:35:43
 Re: John Deere H oil problem in reply to Jerry, 03-24-2000 17:50:05
Aftyer sitting for a couple of years, especially if cylinders and valves not oiled good before storage, my first thought would be stuck rings. I have had good luck with Marvel Mystery Oil in both gas and oil along with a good workout to warm the engine up good and keep it there for a few hours. If the tractor was overhauled before storage it may just need a good work out to re-seat the rings. Hope it works for you. Paul
Jerry
03-25-2000 05:09:31
 Re: Re: John Deere H oil problem in reply to Paul from Michigan, 03-24-2000 19:35:43
Paul, thanks for the suggestion about the Marvel Mystery Oil. MY dad used it years ago in his tractors. I will give it a try. Have a nice day. Jerry
MikeH(Tx)
03-26-2000 04:50:28
 Re: Re: Re: John Deere H oil problem in reply to Jerry, 03-25-2000 05:09:31
Jerry, be careful not to add more than recommended. I did that and fouled the plugs on mine. My H turned out to have too much wear on the cylinders and got a complete rebuild.
Jerry
03-27-2000 17:00:44
 Re: Re: Re: Re: John Deere H oil problem in reply to MikeH(Tx), 03-26-2000 04:50:28
Good evening Mike, Thanks for your reply and suggestion. I appreciate it. Have a nice evening.
Tugboat
03-24-2000 18:04:22
I assume that you have run out all of the old fuel. The thought is that someone may have added oil to the fuel when they stored it away. Tugboat
Jerry
03-25-2000 05:13:16
 Re: Re: John Deere H oil problem in reply to Tugboat, 03-24-2000 18:04:22
"Tugboat", Thanks for the idea about the fuel. When the guy I bought it from added some fuel, it smelled a little like disel. I thought later the container may have been used to fuel tractors needing each of the fuels. I wiil check this out. Have a nice day. Jerry
