1945 g question
WILL
03-30-2000 20:24:59
I FOUND A JOHN DEERE G THATS LP. DO ANYONE KNOW IF JONH DEERE MADE THESE TRACTORS, THIS TRACTOR IS LIKE FACTORY BUILT. EVERYTHING ON IT IS DONE REALY NICE. THE TANK,GAUGES,FUEL LINES,LP CARB. IT ALSO HAS A POWER BLOCK IN IT THAT SAYS 7-1 ON IT. THE G THAT WE HAVE IS LIKE IT BUT IS ALL FUEL TRACTOR. WHAT DO YOU THINK ITS $. ALL IT NEEDS IS REAR TIRES AND FRONT TIRES.PAINT AND THE PISTONS ARE FROZEN UP IN THE BLOCK. ANY INFO THANKS WILL
Stan
03-31-2000 13:27:45
 Re: 1945 g question in reply to WILL, 03-30-2000 20:24:59
From an article by J.R. Hobbs in the September 1996 Green Magazine, "While we're on the subject of fuels, one thing that we know for sure is that Deere did NOT produce "G" series tractors with LP-gas engines, though some experimentation probably went on. LP-gas was a popular and cheap fuel in many areas of the south and southwestern U.S. in the late 1940s and early 1950s and many "G" tractors were converted to burn this fuel. A number of aftermarket companies, notably Ensign, produced kits to convert the "G" to LP-gas operation. The Ensign kit was well engineered and if the directions were followed properly, produced a tractor that was reasonably efficient and looked pretty good." J.R. goes on to talk about some tractors that were converted by "torch artists" and the unfortunate, sometimes fatal, results of some of those conversions.
I hope this helps answer your question.
Stan
mike
03-31-2000 13:57:26
 Re: Re: 1945 g question in reply to Stan, 03-31-2000 13:27:45
HA! sometimes I do appear smarter than I am! Mike
Stan
03-31-2000 14:21:14
 Re: Re: Re: 1945 g question in reply to mike, 03-31-2000 13:57:26
Mike,
You were absolutely right - that is if J.R. Hobbs is right. This might be one of those cases where I have told you more than I know - it happens a lot these days.
Stan
WILL
04-02-2000 16:36:57
 Re: Re: Re: Re: 1945 g question in reply to Stan, 03-31-2000 14:21:14
THANKS FOR THE INFO GUYS.I"M THINKING OF BUYING IT BUT IT NEEDS ALOT OF WORK. THE LP THAT WAS PUT ON WAS DONE REALLY NICE, BUT IT NEEDS TIRES, MOTOR IS FROZEN UP AND WITH THE POWER BLOCK IN IT THE PARTS MIGHT BE HARD TO FINE FOR IT.
mike
03-31-2000 06:43:00
I know of 2 other LP G's but I think they are conversions. I do not believe JD made an LP G. If it has rotten tire and a stuck engine, I'd want to buy it for less than 500. If the fella didn't take it, leave name and # and tell to call you if he changes his mind. I think 500 is generous. Mike
