1010 oil filter substitution help
Jerry
04-16-2000 06:52:02
I have a 1010 RU (gas) with the earlier type oil filter. It is a long drive to my closest JD dealer. If someone has a ID number for a Fram or whatever that I can get at a local NAPA store, Walmart, that would be great.
It is spring tune up time and the distrbutor and points that came from CT Tractor are wrong. Are there any cars that have the same Delco distributor? That would also make things a LOT easier....
Thanks for the help.
Jerry
Duane
04-16-2000 18:26:57
 Re: 1010 oil filter substitution help in reply to Jerry, 04-16-2000 06:52:02
On my 1961 1010U I used a Fram C138PL. Good luck.
mark
04-16-2000 07:10:47
You should be able to go to your napa dealer and find a oil filter in his book by tractor model #. The same with the points. Be sure to give him the model # of the dist. and brand of dist.
