JD 4040s
Jim
10-13-2003 13:31:57
Could anyone give spec for the above tractor. IE Engine, trans, clutch etc as i'm thinking about getting one. Also the build year for approx ser no 439470. Also will it have American or european engine? cheers
BW
10-14-2003 08:34:38
 Re: JD 4040s in reply to Jim, 10-13-2003 13:31:57
They did have a 404, perma clutch, came with syncro, quad or powershift. 90hp can't find my book to look up what year. We had two, real nice tractors for smaller jobs. Hard starters in the cold weather but then most 404's are that I've had anything to do with.
Stuart
10-14-2003 07:22:27
yes they did have a 404 but only a quad range or 8 speed powershift
John
10-13-2003 17:11:47
It has a 6 cylinder, 404 cubic inch engine. 90 horse, Probably the hydraulic/wet clutch called the 'Perma Clutch'. Tranny says 16 speed Quad Range, but may also consist of a 8 or 16 speed power shift or a regular syncro range.
John
Fred G
10-13-2003 20:14:08
 Re: Re: JD 4040s in reply to John, 10-13-2003 17:11:47
Also the 4040 had the 4230's 404 engine, but detuned from 100 to 90 HP. It was a nice step up though from from the 4030's 329.
My guess is that a minor pump adjustment would put you in the hunt for 100HP.
