More 620 Questions
jess
04-20-2000 13:22:14
does anyone know what the ON/OFF valve is for,located on left side beside/under the dash panel.Something for the hydraulics maybe?
Philip Croff
04-20-2000 17:39:25
 Re: More 620 Questions in reply to jess, 04-20-2000 13:22:14
The switch is the Power Trol hydraulics switch. If you run the tractor and you are not going to use the Power Trol, it's best to leave the pump off.
jess
04-20-2000 23:18:31
 Re: Re: More 620 Questions in reply to Philip Croff, 04-20-2000 17:39:25
the previous owner said he left the switch off and the pump overheated.any ideas?
Jack (In GA)
04-20-2000 13:29:15
On my 50, it's the shifter for the hydraulic pump. In the "ON" position a sliding gear is engaged and the pump operates; "OFF" disengages the gear.
jess
04-20-2000 13:39:32
 Re: Re: More 620 Questions in reply to Jack (In GA), 04-20-2000 13:29:15
thanks for the info. i better get a manual
Curt
04-20-2000 17:23:46
 Re: Re: Re: More 620 Questions in reply to jess, 04-20-2000 13:39:32
Make sure you have the engine shut off on your 620 when you engage the hydraulic pump otherwise you will hear the gears grinding.
