1974 JD garden tractor
Pete
04-22-2000 20:33:32
I am considering looking at a '74 JD small graden tractor. I do not know the model. Owner says it is only an 8 hp. He is not sure of the deck size????? ??? Anyone familar with what this may be?? Good little tractor?? Parts available?? Deck size??
Mr. B ~ MI
04-24-2000 05:49:44
 Re: 1974 JD garden tractor in reply to Pete, 04-22-2000 20:33:32
Pete-- I am betting it is old. Built in the 60's, Has Tehcumshe engine, If this is the one, They were good tractor for light duty, but certainly if you are planning to use it I fear you will end up over hauling the engine, And those do not come back without realy doing it up right. I doubt the crank will be good after all these years. They almost always used oil and sooner or later some one forgets to add. I would be surprised if the deck is all that sound any more either. Just look it over real close, Listen to see it it knocks and see it it smokes. Run it and see if it starts hot. Remember it has been out there for around 30 years. If you are just getting it because it is Green-- then all this is expected-- Good luck-- Mr B
