1940 jd g
JR
04-23-2000 14:41:54
engine rebuitb timing ok good fire runs great has lots of power. but will not start without shotting gas in petcock. hand start help thank jr
clooney
04-23-2000 16:33:46
 Re: 1940 jd g in reply to JR, 04-23-2000 14:41:54
Jr, pull the air cleaner inlet & make sure the choke plate is closing completly. If there is a little door on the choke plate with a spring on it, make sure it is there & working. Also try different throttle settings to start it with. Most of mine like almost no throttle to start. Is the fuel in the tank new? Old gas dosn't like to ignite easily.
jr
04-23-2000 19:18:04
 Re: Re: 1940 jd g in reply to clooney, 04-23-2000 16:33:46
gas is good and has old style choke no sring .have made sure choke is working .just will not pull gas to start .started this about last spring before that would start on second or third pull
jr
04-23-2000 19:17:39
